TwinTurbo.NET: Nissan 300ZX forum - If I'm not mistaken, with two separate intakes the
puchy
on July 28, 2016 at 2:56 PM
Re: Re: Re: You need both MAFs plugged in and translator on ADD
posted by Tylerw1
on July 25, 2016 at 05:15 AM
idle is controlled from the driver's side MAF only, because that's where the idle controller's air line is connected to. In another words the passenger side is not sucking air at idle unless you crack open the TB manually.
300zx Twin Turbo running issue
Tylerw1
18:56:25 07/24/16
-Grimm-
00:26:39 07/25/16
backinblack626
00:55:16 07/25/16
Tylerw1
05:04:11 07/25/16
Tylerw1
05:15:51 07/25/16
So when you ordered your ECU chip from CZP
-Grimm-
10:05:15 07/25/16
Re: So when you ordered your ECU chip from CZP
Tylerw1
10:53:42 07/25/16
If I'm not mistaken, with two separate intakes the -
puchy
14:56:25 07/28/16
Tylerw1
11:45:26 07/25/16
Yes. With dual mafs you want to average the signals.. (n/m)
kickerzx
13:14:35 07/25/16
Re: 300zx Twin Turbo running issue
MaxxAction
21:09:52 07/26/16
Re: Re: 300zx Twin Turbo running issue
Tylerw1
17:32:33 07/27/16
